Updates and Kits Customization
I’ve talked about this with support before when solving other problems but…
There has to be a way to retain the volumes of each drum of each kit we customize to our needs!
Or a way to enter by number the volumes we changed?
Or to just copy a drum volume or whole kit volume?
I have to do this every single time there is an update for a big amount kits.
Don’t want to think the users that has to fully alter their kits with fx and more things.
Thank you
Hi @Costas,
Others reading this will be missing the context of our user support email conversation, but I think you may have misunderstood something I wrote in that correspondence.
You can absolutely save your work: just save/save-as to create a .sp2 which will have all of your changes including volume, FX, everything.
There was a very specific problem we discovered in the .sp2 you were using when we had our user support conversation, that meant it was best for you to swap out the hi-hat instruments you had saved in the .sp2 you sent along with your diagnostic report. That was a one time thing, and so now that they have been swapped, you can save them in your own session with all of the alterations you feel like making.
Hi @stevenz
Always helpful!
So it wasn’t necessary for me to do this all over again :joy: . My bad…
There is no need for this topic i guess.
Shall i delete it in order not to confuse anyone else?
Thanks again!
