Hi, just started using the template to send CC notes in order to control drum racks, and other various instruments within Ableton. But every zone on the snare, when struck, senses all midi notes associated with that drum, firing off 10 or so samples at once. Is there a way to get this to stop? There must be something simple im overlooking.
Hi KevinBC,
It sounds to me like blends might have gotten turned on somehow. Make sure you are using the .sps file that goes with the Ableton template and then also double check that blends are turned off.
Let me know if that works.
Stevenz
Oh duh, that was it. Works out now, Thanks a bunch!!
