Hey all, anyone here know if it’s possible to use your drums and the zones on sensory percussion like a midi instrument to control “Output Arcade” it’s a VST instrument that focuses on sampling. any advice on whether this is possible and if so, how to route it would be much appreciated.
This should be doable without too much trouble. Are you using Ableton? I’d recommend checking out this blog post for a primary on setting up MIDI output from Sensory Percussion. The post is specifically about controlling Ableton, but a lot of the concepts are the same for controlling other things.
