Want metronome in dedicated bus but not in main mix
Hi there !
I’d like to use the metronome with my sets. So I made my metronome sequencer with the metronome module. I route it to a bus to control it. But my problem is : i don’t want to hear it in the main mix, is it possible?
Thx for help !
Hi @Bo33 - at the moment there’s no way to remove a layer from the main mix. This is something we have on our list to add specifically for metronomes.
For now what you’ll have to do is create two new submixes: one with just your metronome and a second one with everything except for your metronome.
Hi Tenoch !
Ok ! Thx for the answer !
hi @bo33,
Just wanted to chime in to add I think you could also achieve this with just one submix, like in this video:
You can see that the click is muted in one mix, but not the other. This method doesn’t technically remove the click from the “main mix,” but since any mix can be routed to any output, I’m not sure that there’s a use case where that distinction matters. This definitely covers the most common metro-related use case, which is wanting the click to go out to the headphones, but not to the main outs of the EVANS Portal. Hope that helps!
