2.7.0-beta4 just released
We have a new beta for you all to try: 2.7.0-beta4.
This release is built around presets and session workflow: a full preset system for effects, controllers, and generators, plus a new multi-session workspace that lets you switch between and manage sessions from a single file menu. It also brings sidechain routing to the compressor, a new Gate effect with sidechain and metering, a new Bit Crush effect, expanded MIDI notes generator options, new sequencer modes, and a wave of metering, navigation, and stability improvements throughout.
Open the beta app to update or head to https://sunhou.se/downloads/beta to grab the installer.
Please give the beta a try and let us know what you think with the ‘Beta Feedback’ button in the app.
Added
- Add a preset system for effects, controllers, and generators, with a preset
  picker, factory presets, and per-type module defaults
- Load module presets from .spp files by drag-and-drop onto module cards and
  child lists, or from a load-from-file menu entry
- Create a layer by dropping a .spp preset file onto an empty lane
- Add a workspace/session slot switcher with a contextual file menu and save-copy,
  revert, and close-session commands
- Add live-value tracking on parameters with a divergence indicator, save/reset
  menu options, and a remember-live-changes preference
- Add sidechain routing to the compressor with source and tap selectors, detector
  and gain-reduction meters, and attack/release stage-activity dots
- Add a Gate effect with sidechain support and detector metering
- Add a Bit Crush effect with jitter and shape parameters
- Add random hop and shuffle sequencer modes
- Add choke and hi-hat pedal support to the MIDI notes generator
- Stream snare center-to-edge position as a CC from the MIDI notes generator,
  with position CC controls in the UI
- Add layer distribute options and an editable main-mix layer list
- Add collect-session-in-place to save a collected copy next to the saved session
- Add average, peak, and peak-hold levels to level meters
- Add go-to-source and go-to-targets navigation for assignments
- Macros now show target units and dynamic names, and double-click resets to
  the target default
Changed
- Default the sequencer to step-before-trigger timing and remove the legacy
  timing toggle
- Decode session samples in parallel for faster session loading
- Raise the level meter refresh rate to 60fps
- Auto-open the assignment popup after drag-and-drop
Fixed
- Key audio device preferences by a persistent identifier so renamed devices
  keep their settings
- Rotate last-file generations on save and recover the previous generation when
  a session fails to load
- Back up an unreadable workspace before falling back to the demo session
- Fix first-launch window inset on notched Macs
- Fix the initial window size on Windows
- Fix factory presets not installing on Windows
- Keep long tooltip hints from clipping their opening words on small windows
- Don't stack update dialogs on periodic version rechecks
Very cool!! Thanks for the update.
Hey all – we just released 2.7.0-beta6
This update has some UI refinements over beta4. It also includes a change that further reduces latency on cymbal and hi-hat sensor inputs. Give it a try and let us know what you think!
