I need to be able to hear both the audio I already recorded to another track in Ableton with what I’m playing live in Sensory Percussion.
I tried setting the Audio MIDI to Headphones L/R instead of Main Out L/R as advised in another post, but that didn’t work.
              Hi @crisbeasley,
Can you make sure that your recorded Mix Out channels aren’t muted? (they are muted by default, as to avoid doubling the output):
And, it sound’s like this is not the issue, but just in case, make sure that your main outputs are set to 3/4, not 1/2:
              The 3/4 issue was it! Thanks for being so speeeeeeedy Steeeevenz!
