Triggers do not react properly
Hi Folks!
I´ve just installed all the Triggers to my Set. Now want to control GGD Invasion Drums in Logic with the Triggers. Unfortunately many Hits of serveral Drums are not being recorded or recognised by the Sensors. I´ve allready played around with the Sensitivity, Threshold etc. but it still doesn´t work and too many Hits are not transferred into Logic.
What can i do?
And one more Question: How can i fix Latency Issues?
Thanks for helping me out!
Are you hearing hits properly if you load a preset in Sensory Percussion?
Its hard to tell what the issue is without more info, but if you’re just missing hits going into Logic, then it could be a midi mapping issue. Sensory has a lot more zones than can be used by other drum software, so you’ll want to make sure that for each zone that you train, you have a midi note mapped to it that will trigger a sound in Logic. You will end up with multiple zones sending the same midi note.
You can check out the Superior Drummer 3 template for an example here: SP2 to SD3 MIDI Mapping Templates
If it seems like you’re having a different issue, don’t hesitate to reach out to support@sunhou.se and share more details about your setup.
