Triggers do not react properly
Are you hearing hits properly if you load a preset in Sensory Percussion?
Its hard to tell what the issue is without more info, but if you’re just missing hits going into Logic, then it could be a midi mapping issue. Sensory has a lot more zones than can be used by other drum software, so you’ll want to make sure that for each zone that you train, you have a midi note mapped to it that will trigger a sound in Logic. You will end up with multiple zones sending the same midi note.
You can check out the Superior Drummer 3 template for an example here: SP2 to SD3 MIDI Mapping Templates
If it seems like you’re having a different issue, don’t hesitate to reach out to support@sunhou.se and share more details about your setup.
